need sum help
Which fuse(s) is the problematic, what is it rated for? As said, try running the separate 12V line from the battery, just to see if there's something wrong with the head unit or not. What head unit are you trying to hook up?
everytime i install my cd deck i blow a fuse where it causes my dashboard and tail lights to go out.. why is that?i even took it to get installed by best buy and it is still doing the same thing..
You have your ground hooked up to a dimmer wire.
Some older GM cars use a brown wire for the ground and the black on is the dimmer.
What make and model is your vehicle?
lildee24
lildee24
VA
Johnny Drama
