Need suggestions for my system before i buy it
the front speakers are good but you can probably find them cheaper.
you might want to substitute the rear 6x9 for the 6.5" coaxils.
the sub amps id ditch those options alltogether, althought the rockford is a beast you can get 1000 rms cheaper and just as good quality.
for the subs its your call. ive never heard the type r's but i have heard the rockfords and i wouldnt buy them. from reading on this site ive pretty much gathered that the alpines will sound pretty d@mn good given a proper install but they might lack a bit on the spl. 2 12" sq subs would be loud enough for me anyway.
my question is why get rockford fosgate at all...and why is audiobahn on ur list?
ok, rockford fosgate out.
about audiobahn...coz they are stable @ 1ohm and a bit cheap option.
but now i also found kenwood amp. x811d. 1000 rms @ 1 ohm. like 200$ shipped.
should i go for kenwood?
i bought Boston acoustics FX6 for the rears as ANALOGKID adviced , get 6.5".
now the question is which AMP? also is there any other option for Fronts (kappa perfect 6.1) without compromising quality but price ?
thanks
audiobahn dont test teir amps at loads, so some of them might not be stable at 1ohm... pay a lil more for an amp... get the Nine.1 from eD for a better pcie and will do about 1500w
Good suggestion on the ED 9.1
Use the system builder discount, you can pick up some deadening for basically free.
Youll get around 1500 out of the amp, and its rated stable at 1 ohm, but some people run it at 1/2 hm daily. Very solid amp.
About Rockford, they arent bad amps. They wont sell an amp that doesnt do its rated power, they just tend to be quite expensive when compared to other amps of the same power build quality.
Dont let that statement lead you to believe they arent good amps.
Nmaximist
Nmaximist
Toronto,ON
Nmaximist
michigan born
    May 14, 2026
michigan born
    May 14, 2026
