Need Sub Recommendations
Looking to get 2 15’s, need some recommendations, looking to get both for under $1k, need something that would sound nice and clean, good sql and spl. Open to all suggestions thank u
Look at Sundown and Fi. Which amp do you have? Which box and vehicle do you have? What is your electrical situation? Details are everything.
2 skar rp2000, my batteries and alternator are good they drop to around 13.3 volts, in a 4.5 cu ft box tuned to 34, i had 2 AB TNT 15’s but im trying to upgrade now.
@NDPTJB your box is Too small at 4.5 cubes For two 15” tnt’s. minimum advised by ab is 2.75-3 per sub and likely more. Also after impedance rise you’re probably not feeding those subs anywhere near 2k probably Closer to 1k each. Get a larger box and bigger amp you’re going to have to anyways if you upgrade subs which you haven’t tapped anywhere near their potential
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
I'd be willing to pay for a quality HU, if it meant that I can truly get the sound quality I need. I've seen some aftermarket ones that look...
10
627
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
NDPTJB
CarAudio.com Recruit
NDPTJB
San Diego
denim
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
