Need some help with sub choice for shallow mounting depth
stonedge
32
bc
Hi guys, just picked up a new tundra double cab. Need to throw something in so I'm coming here for suggestions. I'm looking at a custom box that is 2.1cu ft slot port tuned to 35hz for 2 10" subs. Mounting depth is 5". Normally I would build a box but it would be an absolute pita in this setup.
I've been out the game for almost 5 years and currently run an IDMAX 12 v3 2.6 cu ft tuned to 30hz off a pg ti 600.2 in the car.
I have 2 amps at my disposal
the PG ti 600.2 or the ti 1000.2 sitting on the shelf.
Looking for more of an sq/sql setup (i hope I can customize the box a little)
So I'm looking for shallow mount subs more sql if possible. Can you list a few that fit the bill? Greatly appreciated.
Yeah I realize that, should of been more clear when I said I wanted to customize the box a little i.e. tune a bit lower. Memphis and mbquart, thanks for the opinions I'll have to do some research on them. Anyone else with input? Appreciate it thanks!
stonedge
stonedge
bc
stonedge
michigan born
    May 14, 2026
michigan born
    May 14, 2026
