azimuth
funded*by*soros
his calculations are right. at least before port displacement. knowing the width and lenght of the port is needed.
your drawing shows 19x16.5x15.25Ok so heres the scoops. Get 2 Type ARRRR 10's that tryin to build a box for. Goal was for 3cubes net after all disp. tuned to 30hz. Well my ingenius self built the box and didnt take into account the freekin trunk opening!! Sooo I have to build 2 smaller boxes to make it work. This is the best design i could come up with.. its just a tad under 1.5 after disp. again tuned at 30, subs firing to the side and port back. My biggest concern is the distance between the basket and the port wall. Its marginally less than the port width. Car is a 95 Accord, powering em with zx1000.1 @ 2ohms(2subs) max dimensions are 33wX19dX16h but again have to be broken into two boxes to fit. So 16.5wX19dX16h outside dimensions per box.
Any critique or better ideas would be appreciated..thanks
i see where the confusion comes in but i did list all my dimensions in my post, i just left the top panel off so you guys could see the port configuration..no worries at least i know im not crazy...lol thanksyour drawing shows 19x16.5x15.25that comes to 17.5 x 14.5 x 13.75 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
//content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif I was on my way out the door, so at least you cleared it up.you will destroy the sub if it cannot vent at the pole it will cook
and u need to use inside dimensions not outside to get internal volume there sport //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
you have 17.5 x 15 x 13.75 internal so at best 1.35cf net
