Need some help from the smart guys please....
but thats what i thought i am using please re-read my post and tell me where im wrong
if 16.5 x 19x 16 is external then wouldnt 1.5" from all sides be 15 x 17.5 x 14.5???
he said my dimensions are 17.5 x 15 x 13.75...thats where im confused
Ok so heres the scoops. Get 2 Type ARRRR 10's that tryin to build a box for. Goal was for 3cubes net after all disp. tuned to 30hz. Well my ingenius self built the box and didnt take into account the freekin trunk opening!! Sooo I have to build 2 smaller boxes to make it work. This is the best design i could come up with.. its just a tad under 1.5 after disp. again tuned at 30, subs firing to the side and port back. My biggest concern is the distance between the basket and the port wall. Its marginally less than the port width. Car is a 95 Accord, powering em with zx1000.1 @ 2ohms(2subs) max dimensions are 33wX19dX16h but again have to be broken into two boxes to fit. So 16.5wX19dX16h outside dimensions per box.
Any critique or better ideas would be appreciated..thanks
your drawing shows 19x16.5x15.25
that comes to 17.5 x 14.5 x 13.75 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
your drawing shows 19x16.5x15.25that comes to 17.5 x 14.5 x 13.75 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i see where the confusion comes in but i did list all my dimensions in my post, i just left the top panel off so you guys could see the port configuration..no worries at least i know im not crazy...lol thanks
measure the remainig un ported area it is much easier //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif just divide it into 2 rectangle areas and figure it up that will be ur VB
awesome..much obliged gentleman!!! ill go back and try and figure some stuff out as this box apparently wont work worth a cr@p...i do appreciate all the help. I hope you guys will chime in again for my next mistake..lol
PART 2!!!!!
Ok so after you guys help I decided to redo and found 30hz just aint gonna happen. So new box is just under 35hz same original dimensions ( 16.5x19x16 ext) but new port is 1.75x14.5x33 and after acounting for all wood and stuff I get a port disp of .87 so this should leave me right where i want @ 1.5 cubes that the sub sees. Please let me know if theres any screw ups in this one. thanks in advance
you will destroy the sub if it cannot vent at the pole it will cook
and u need to use inside dimensions not outside to get internal volume there sport //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
you have 17.5 x 15 x 13.75 internal so at best 1.35cf net
//content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif I was on my way out the door, so at least you cleared it up.
I also just checked the voltage and the voltage on the amp in 12.85 and the rest of my stuff like my lc2i and remote out wire is 12.10. could that...
61
676
739
966
SPOOLEDCRXB18
SPOOLEDCRXB18
Hawaii
SicAudio
    May 18, 2024
    May 18, 2024
