Need Setup Help (Camaro)
Drew'sZ
I searched and didn't find what i need. I have a 2000 Camaro and need some setup help. I listen to mostly Rap and some Rock, so my ststem will be setup for Spl but i want to be able to hear the words of course. Should I go for 2 component sets for the front and rear then the subs or 1 component set for the front, 1 pair of coaxials for the rear, and then the subs. Maybe I should run 1 component set for the front and the subs. I have enought money for what ever setup will sound better. Thanks for the help.
Start with some goood components up front and a sub, If you want something in the rear use a coaxial set back there with less power than you are putting on the front set.
people on here will generally tell you rear fill is useless unless you have alot of people riding in the back seats. if you want rear fill some good coax speakerx will do the job.
Drew'sZ
Drew'sZ
Fayetteville, NC
Drew'sZ
michigan born
    May 14, 2026
michigan born
    May 14, 2026
