Need Orion 275G4 specs
low00ranger
Does anyone know what these amps really produce at 2 ohms bridged? How about 4 ohms bridged, and 4 ohms per channel?
I have this amp running at 1 ohm and it currently makes my lights dim really bad when I crank it up even though I have a 200A alt and 4 gauge all around. I am downgrading my system from a street-beater to something that just sounds good and gets low enough. I have 1 DD1008a on the way and might get another. If I run this amp at 2 or 4 ohms, only drawing 1/2 the power I'm drawing now, should my dimming problems improve?
It would only be 1/2 to 1/4 of the power that you are drawing now. You need to upgrade your wiring from 4 ga to 1/0, big 3 too. Without upgrading wire that 200a alt isn't doing you much good. Also it probably puts out less at idle than your factory alt which won't help the dimming situation either.
low00ranger
low00ranger
USA
helotaxi
