need opinions bad
thekidd2008
ok So i have a 03 Hyundai Tiburon gt v6 . I have the door and rear speakers in all ready running of a 4 channel Memphis Amp (Memphis 16 ST3004) sound alsome. Ok But this is the hard part i dont know what kind of subs to go with and wat size ( me personally it was either 2 10's, 2 12's or 2 15's) but in order to do the 15's i was gonna let the back seat down. The amp im goona be running is DD M1b for the sub specs are here (DDM1b Amplifier - DDAudio.com | Digital Designs : Speakers Made in the USA)
Thank In Advance:)
I think a DC Level 4 would be alsome your amp would give it like the best power. ok I would probly due teh 12" bcuz your vehicle dont have a hole lota room. U shuld give the sub like 1.5 - 2.0 cubic fete tuned to 35Hz.
214
Thanks for your input! I did some research and wanted to share what I found for anyone else in a similar situation. It turns out that the Honda...
181
511
thekidd2008
thekidd2008
LittleRock,Ar
misfit138
    May 20, 2024
    May 20, 2024
