Need info on SA-8
box is like .6--1.2 i think after displacment. and like normal smaller box for more power. mine was like .65 per sub after displacments and it sounded just fine IMO...and i beleive ts specs are on caco in the sundown section
Product Description
Pre-Order pricing!! Pre-sale in USA only.
SPECIFICATIONS OF D2 Coil :
RE: 3.28 ohms (series)
FS: 41.6 Hz
Qes: 0.513
Qms: 6.606
Qts: 0.476
Le: 2.778 mH
Vas: 3.285 L
BL: 17.138 N/A
Cms: 83.341 um/N
Mms: 175.654 g
Sens: 78.476 dB @ 1w/1m
Dual-4 SA-8 Specs:
RE: 6.08 ohms
Fs: 44.66 Hz
Qes: 0.594
Qms: 6.337
Qts: 0.545
Le: 4.26 mH
VAS: 4.44 L
BL: 21.20 N/A
Cms: 80.8 uM/N
Mms: 157 g
Sens: 80.06 @ 1w/1m
BL^2/RE: 73.92
POWER: 400 RMS
5.25" depth
8.25" overall basket OD (no gasket)
7.375" cut-out diameter (without gasket)
7.25" cut-out diameter (with gasket)
6.25" magnet diameter
We suggest 0.6 - 1 cube ported tuned to 30-40 hz based on your goals and preferences. Sealed can be utilized but is not optimal for these drivers.
Mine do //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif After they are nice and broken in they like alot more power.
hmmm maybe...i didnt have mine for long at all. but then again like 5 other members have told em the same thing
They don't really need more than rated power -- they are a 2" coil driver after all.
Regardless I can't think of any other 8s out there that will handle more power thermally -- the other "big boy" SPL eight (DD 1508) has almost exactly the same size coil.
they are very nice 8's...
Thinking about getting a pair, I'm not going to send more than 400 watts to each. Kinda hoping they holdup a little better than the e8s I've played with. I loved the e8 but I tried to get a little to much out of it and it didnt like it.
E8 had a very soft spider -- they meant it when they said 200-watts.
if youre trying to get loud then the e8 is probably not a great idea. I use them for a nice low fill. Spiders are waaay soft. I have my two SA-8s in 1.9 w/ 4" aero and with the right amp will do 140+. I think you get more out of them if you have them tuned up to around 35-38 although Im still playing around with them.
Well i had up to four e8s in a regular cab truck and it got loud for 8"s on about 1000 watts. Its the mechanical limits of the sub, not the coil, that I'm worried about. I think I had too much port area on the e8s, I had four in 2.4 cubes with a 6" port. I'll drop it down to about 800 watts in 1.6 cubes with a four inch port for two sa8's. May try tuning a little higher as well, I think I had the e8s at 30-32 hz. I'll probably do 35hz with the sa8. Please dont misunderstand the e8s are great little subs as long as they are used as intended.
Slo_Ride
Regulator
Slo_Ride
ATLANTA
sjobas
Mike Mccabe
