Need help with Installation Please help
  • 2
IloveTheBass
18
LA,CA
Hello everyone well,
I have a Kenford Amp and a Jl Audio Sub
I really need help on how I should connect this as I do not know much about this stuff i can provide the specs.
On the amp it says:
-2 OHM STABLE
-BRIDGEABLE HIGH POWER 2CH AMPLIFIER
-T.H.D 0.03%
-MOSFET CLASS "A"
-BUILT IN CROSSOVER
-250W + 250W = 500 W
and the sub specs are as follow:
Key Features:
Car Speaker Function Subwoofer
Size 12"
Type Component
Elements 1-Way
Powered Non-Powered
RMS Power 300 W
Technical Features
Impedance 6 ohm (Duel Coil)
Sensitivity 86.9 dB
I do not know how to connect this like
should I bridge? What wire gauge do i need?
Etc..
Any help I would really appreciate it since I really want to get into this.
I can post a pic of the amp if you'd like
Thank You
Research! you will probably get more info on google or youtube like I did.
anyways just buy an amp wiring kit from a Walmart they have different max wattage and it includes almost everything you need. for you buy the 670 watt max kit Im assuming. I would bridge
We are in the same boat here, I've only had my vehicle for about 6 months. I don't know much about this either but google bridging and select the safer option at first to test then if you are not satisfied with the level of base then look into the not-as-safe option
461
849
853
IloveTheBass
IloveTheBass
LA,CA
colmc11
    May 31, 2024
    May 24, 2024
