IloveTheBass
Hello everyone well,
I have a Kenford Amp and a Jl Audio Sub
I really need help on how I should connect this as I do not know much about this stuff i can provide the specs.
On the amp it says:
-2 OHM STABLE
-BRIDGEABLE HIGH POWER 2CH AMPLIFIER
-T.H.D 0.03%
-MOSFET CLASS "A"
-BUILT IN CROSSOVER
-250W + 250W = 500 W
and the sub specs are as follow:
Key Features:
Car Speaker Function Subwoofer
Size 12"
Type Component
Elements 1-Way
Powered Non-Powered
RMS Power 300 W
Technical Features
Impedance 6 ohm (Duel Coil)
Sensitivity 86.9 dB
I do not know how to connect this like
should I bridge? What wire gauge do i need?
Etc..
Any help I would really appreciate it since I really want to get into this.
I can post a pic of the amp if you'd like
Thank You
On the amp it says:
-2 OHM STABLE
-T.H.D 0.03%
-MOSFET CLASS "A"
-BUILT IN CROSSOVER
Key Features:
Size 12"
Type Component
Elements 1-Way
Powered Non-Powered
RMS Power 300 W
Technical Features
Sensitivity 86.9 dB
Etc..
Thank You
