need help with box build specs for airspace
need box dimensions so i can give the proper amount of airspace for my subs. im going to drop in two 12in shallow mounts. im up in the air between Memphis and RE. if i dont have enough airspace for the 12's im going to drop in some tens. can i please get the cut dimensions for both sizes and brands. i dont know how to figure this out. i attached a picture of the old setup. i ripped out. just to give you an idea if any of you have worked on this type of truck before. thanks alot. steelreignfa@Yahoo
Well first you need to figure out how much room you have to work with and then you can figure out how big of a box you can fit. From there you can figure out what subs would work best in that enclosure.
I was wondering about that as well, if i make the box the to big even if i had enough room for both subs wont that still affect the subs in a negative way? i heard theres a optimum and a minimum amount of space recommended for airspace.
Yes but if you measure the space we know how much room you have to work with.
my82c10
my82c10
canyon lake california
geonfreaq
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
