Need Help With Amp Wiring/Gain Setting
JakeM
First of all I dont get wtf
Sqrt(Power*Resistance) = Voltage
means. So im hoping you guys can help me.
Sub Amp-Clarion DPX 1000.2
Putting 2 RE 12 (4ohm DVC) this is how im going to wire them
My amp is
250x2 into 4ohms
450x2 into 2ohms
1000x1 into 2ohms
So if I wire the subs like I showed you and bridged it to the amp I would get about 500 to both subs or 250 to each, right?
Ok also how many volts(using that formula above) would I need to set my gain to?
Also should I switch the amp to Mono?
Ok now that thats over I just got in my Clarion APX 200.2 and PG ZR 6.5 Comps
PG=4 ohms each
Clarion=50x2 @ 4ohms
So how would I do that dam formula?
Sqrt(50*4) = 14.142735
Am I Right?
So if I wire the subs like I showed you and bridged it to the amp I would get about 500 to both subs or 250 to each, right?Ok also how many volts(using that formula above) would I need to set my gain to?
This has been answered in the other section.
Ok now that thats over I just got in my Clarion APX 200.2 and PG ZR 6.5 CompsPG=4 ohms each
Am I Right?
Ah hell, just do it by ear, if you've gone over 50% of max sensitvity you've gone too far.
set it really low, listen to it, tweak it up a bit, listen to it and just keep tweaking untill it sounds good to you. This does not work for somepeople as they don't have a clue what distorted sound is, they just want it loud.
JakeM
JakeM
Houston
stones
