need help wiring
According to http://www.treoonline.com/csx.html those subs are 2-ohm DVC. A 2-ohm DVC can be wired in parallel for a 1-ohm load, in series for a 4-ohm load, or each voice coil can be amped seperately, for 2 2-ohm loads.
The specs for your amp:
Bridged:
650w @ 4 ohm
900w @ 3 ohm
1200w @ 2 ohm
Stereo:
170w x 2 @ 4 ohm
260w x 2 @ 3 ohm
360w x 2 @ 2 ohm
400w x 2 @ 1.5 ohm
To get the most power, you should wire each voice coil to a seperate channel on the amp. Then, make sure you feed each channel with the same signal (split a mono signal with a y-cable). Make sure the gains and filters are set exactly the same on each channel on the amp. This should give you 720w to your sub.
To get the full 1200w to the sub, you would need a 4-ohm DVC sub, or a 2-ohm SVC.
Bridged:
650w @ 4 ohm
900w @ 3 ohm
1200w @ 2 ohm
Stereo:
170w x 2 @ 4 ohm
260w x 2 @ 3 ohm
360w x 2 @ 2 ohm
400w x 2 @ 1.5 ohm
noooo!!! subs sometimes have multiple coil configurations to allow you to change the impedance presented, not to use more than one amplifier.... you should not use more than one amp per sub unless your amps are strapable... otherwise, it is not a good idea to do this for daily use... its not even a good idea to wire each coil to a serperate channel
i dont think that amp is 1-ohm stable, so you're gonna have to wire the sub in series and run it at 4ohms
Trez0r
eh
Trez0r
Canada, Saskatchewan, Regina
wesl56
