snowpromod
Hi All,
Thanks for the great site, I have been reading a bunch and just when I think I understand something, I realize I still am a rookie.
Looking to install the following items in my boat - looking to set it up properly the first time. Here is the equipment that I have:
AMP - ZED Leviathan II
Tower - 2 Wetsounds Pro 60's - Impedance:4 ohms, RMS Watts:150, PEAK Watts:300, Frequency Response:20Hz to 20Khz, Sensitivity:90db at 1watt / 1meter, Mid Bass: 6.5" inch EFG™ cone woofer with polyurethane surround, High Frequency
ro-Axial™ Driver. Coaxially mounted Titanium Diaphragm High Output Horn Loaded Compression Driver
Tower - 2 Wetsounds MB-8's - Impedance:4 ohms, RMS Watts:150, PEAK Watts:300,Frequency Response:20Hz to 20KHZ, Sensitivity:91 db at 1watt/1 meter, Mid Bass:Single 8 inch EFG™ cone woofer with polyurethane surround, High Frequency
In Boats - 4 JL Audio M770-CCS-CG-WH - Specifications Sensitivity 91 dB, Frequency Response 45-25k Hz, RMS Power Range (Watts) 40-100, Peak Power Handling (Watts) 175, Impedance (Ohms) 4
Looking to run everything off the Zed amp if possible, trying not to blow anything up, LOL.
My thoughts were to wire each tower speaker to a channel - 4 speakers on 4 channels. The in boats I was going to wire in parallel - 2 speakers to 1 channel, so in the end I would use all 6 channels on the amp. Does this sound right?
