Need Help on first high power Setup! Single DC Audio 15"
It's an M2 but I just picked up a Skar ZVX 15 D2, in the same box, dumping ~1500RMS on the 2K Brutus and it's stupid loud. No comparision between the two. This one picks up lows the other would not. It gets nasty to 25HZ, where the Level three had a hard time pumping 30HZ.
The lvl 3 will not have any issues playing low notes. It just needs the right box. 2 different subs will not always work the same in the same box. My daughter has a lvl 2. 15 on 800 watts rms in a 4.5 cubic ft box tuned at 32 hertz and it's gets very loud and stupid low
Box was to spec for the DC audio Level 3, built by a local builder that builds boxes for a living. The Skar just gets dirty loud and is clean sounding. The DC was great don't get me wrong, but the ZVX is more of a level 4/XL matchup rather than to a level 3.
662
728
959
corrykid
corrykid
Bonney Lake, Washington, United States
corrykid
    May 18, 2024
    May 16, 2024
