Need Help Installing
Fir3controlman
Over the past few weeks I've been buying car stereo parts for my 2000 Ford Mustang and this weekend I will be installing it. I have
- 4 6x8 pioneer 40 Watt RMS, 240 Watt max, 4 ohm speakers
- 2 JL Audio 10" W6 subwoofers 300 RMS, 6 ohm
- Kenwood KAC 8404 600 Watt Max, 50 Watt RMS x 4 (4 ohms) (for my speakers)
- Kenwood KAC 8104D 1000 Watt Max, 300 RMS 4 ohm/1 chan
- 2 Jarad capacitor
- Alpine CDA-105
So far I've hit a few small snags, the reason I had to get a new system for my car was because my stock amplifier was draining my battery when it wasn't running. Something was wrong with the fuse so I decided to just buy a new system (the last few months I've been saving up for a new one anyways). I had one of my buddies look at my car and he says I'll have to re-wire my new speakers to my new amplifier and have my amplifier run to the head unit. Seeing as I'm a complete novice to this and I don't have enough money to have it professionally installed. I'm hoping someone can give me directions to doing this install on my own or a website that would help me. Also anything else I might need for my system?
You do realize that the Kenwood mono amp is FAR too weak to adequately power the W6s, right? The cap is useless as well. You should've done some research before buying this stuff.
If you want advice on the install, pm me. I'll give you some advice and walk you through the process...
Fir3controlman
Fir3controlman
Northern Virginia
Bumpin' Goalie
