Need help! Brz 2100 RCA complications
psykotyk
Hey I just bought a hifonics brutas 2100 and when I hook everything up the amp it wont power on but when i plug the RCAs in output on the amp then it powers on.. Why would this be happening? I've tried RCAs and even used a new deck! I took the amp into audio video and they had it working in their shop.. Anything I havn't tried? Or something to try? Thanks
Check to see if you have a good ground for the amp.Scratch paint away,ect first.Sounds like Bad Grounding issue for the amp.Try that.I will chk later n the day to see what you came up with see if it may be something else
psykotyk
psykotyk
los angeles, CA
akheathen
