jalverson
my face got jacked!
I have a 2001 Mustang Convertable, so not a ton of trunk space as you may know. I have a sub that requires 1.5cu/ft to 2.25 cu/ft. Now I am not sure of the truck dimensions or even where to find that out. The sub is an MA Audio HK12X2 here are the sub specs as best as i can find. For some reason MA Audio's website doesn't have anything on there. please lemme know if someone out there can help, i am kinda stuck on what to do with this install. Thanks!
Sub Specs:
1500W RMS
3000W Max
Sensitivity: 88.9dB @ 1w/1m
Mounting Depth: 8"
Mounting Diameter: 11"
Optimum Vented Box: 3 Cu/Ft
Port Area: 48 Sq/In
Port Length: 14.5"
Optimum Sealed Box: 1.5-2.25 Cu/Ft
Dual 2 Ohm Voice Coil
Aluminum Round Wire Voice Coil
Hi-Temp Kapton Voice Coil Former
400oz. Double Stacked Strontium Magnets
Patented Thermo-Cooling Motor Structure
Bumped Back Plate For Max Excusrion
High Roll Triple Layer Ribbed Surround
Double Layer Progressive Spiders
Dual Layer Pressed Carbon Fiber Cone
Ultra Strong Carbon Fiber Dust Cap
Rubber Sealant Gasket
Sub Specs:
1500W RMS
3000W Max
Mounting Depth: 8"
Port Area: 48 Sq/In
Port Length: 14.5"
