Did you not listen to the system after the guy installed it for you? Did you not tell him it sounded bad?no i havent touched anything
---------- Post added at 07:20 PM ---------- Previous post was at 07:19 PM ----------
im currenly at work but i can load pics later when i get off
If you settle down a little bit, and go step by step with us, we should be able to walk you through and troubleshoot to solve your problem without going through all that hassle.I was actually at work im gonna take everything out tomorrow and take it Crutchfield
Can tell you right now your LPF is set far to high and your gain is also set way to high.Ok..... Im in my car looking at the amp now and the settings are as follows
LPF about 100hz, SSFabout 25hz, Bass EQ zero degrees, phase zero degrees, level at about 10oclock with 9v being to your far left and 0.2v to your far right
Ok that's good. Now you need to use the DMM to calculate where your gains need to be.Ok subs are reading 1.9-2.1ohms
