need an amplifier installation kit + other wires
Do you plan on upgrading to a speaker amp in the future? If not, 4awg will be fine for now. As far as I know, there are no kits that come with extra wire specifically for the Big 3, I can build you a custom kit, but as far as one goes in the retail market... good luck. You should do the Big 3 in as big of a wire as you can afford. For the sub, 14awg would be fine, you could go as big as 12awg, but 14 should be fine.
actually yea i want to add a speaker amp later on down the road, but for now will i have to put in a distribution block? i would rather not put one in now just wait till i actually get the next amp
but just a overall summary, all i gotta do is hook up rca's from headunit to amp, then run power wire from amp to battery terminal, run ground wire from amp to ground location , and thats just basically it? where does the remote wire on the amplifier go? does it goto the headunit's wiring harness remote wire?
sorry if im asking noobish questions, i just want to make sure 100% i know what im doing before i do it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You got it in the remote question. Hook it to the HU.
As far as the power goes, just get a distro later if you would rather not get it now.
You've got everything else correct.
Twistid
Twistid
in a space out of sound
snb778
