I need Help picking the right amplifier
The sound of a 1 ohm driver is the same as the same driver at 4 ohms, not sure what the question is here. Are you asking the OP was there a volume difference due to it being 1 ohm and drawing more power from the amp?
Product Highlights
Features​
  • Digital Class-D: Packs a powerful punch with high efficiency and an incredible small form factor.
  • Small Footprint and Sturdy Design: Built to the highest standards for lasting reliability.
  • Robust Unregulated Power Supplies: Designed to provide superior performance and unmatched efficiency.
  • Designed with Advanced HEXFET® Power MOSFET: Reduced on-resistance, faster switching speeds, and unparalleled reliability.
  • Direct Insert Power and Speaker Terminals: Decreased resistance for higher power transfer and efficiency.
Description​
Take your Stinger car audio to the next level with the MT Series by Stinger Audio: sleek, compact multi-channel amplifiers designed to integrate into any vehicle sound system. Harnessing the power of Class D circuitry, these amplifiers efficiently drive your speakers, producing clarity and vibrancy in sound reproduction. Utilizing advanced MOSFET technology alongside top-tier capacitors, transformers, and cutting-edge inductors, our amplifiers deliver a sonic experience that transcends expectations. Enhance your drive with the Stinger Audio MT-1000.5 1200 Watt 5 Channel Amplifier.
Model NumberMT-1000.5
Channels5/4/3
Continuous Power (RMS)
(<1% THD @ 14.4V)
150W x 4 + 500W x 1 @ 2Ω
75W x 4 + 300W x 1 @ 4Ω
300W x 2 @ 4Ω
700W x 1 @ 1Ω - CH5
S/N Ratio @CEA Standard-90dB
Input Sensitivity0.5v-11v
Gain0.5v-11v
Frequency Response10Hz - 180KHz
Bass-Boost Frequency RangeCH5: 10Hz-180Hz
CH1-4:10Hz-20KHz
Bass-Boost Q0-12db
Efficiency (Average)80%
Topology ClassClass D
Crossover xover MultiplierX1: 50Hz-500Hz
X10: 500Hz-5KHz
40Hz-180Hz - CH5
Remote Level ControlIncluded
Operating Voltage9V to 16V
Power Terminal4 Gauge
Speaker TerminalCH1-CH4:12AWG
CH5:8 Guage
Recommended External Fusing150A
Dimensions13.23in/336mm L
2.09in/53mm W
6.10in/155mm H
Zach H
CarAudio.com Newbie
Zach H
florida
AnthonyO
