Need an amp for around $250
http://www.sundownaudio.com/
Rated power output
-RMS power, 2 ohm linkable/dual mono ------
-RMS power, 1 ohm mono ------------------------
-RMS power, 2 ohm mono ------------------------
-RMS power, 4 ohm mono-------------------------
Signal to Noise Ratio -----------------------------------
Low pass frequency crossover ---------------------
Subsonic filter ----------------------------------------------
Bass boost @ 45Hz -------------------------------------
Phase shift control----------------------------------------
Frequency response--------------------------------------
T.H.D @ 4 ohm----------------------------------------------
Efficiency @ 4 ohm-----------------------------------------
Fuse rating---------------------------------------------------
Input Sensitivity -------------------------------------------
Dimensions---------------------------------------------------
1800W x 1CH
1000W x 1CH
600W x 1CH
300W x 1CH
>90dB
35Hz~300Hz
10Hz~60Hz
0~18dB
0~180 degree
10Hz~350Hz (+/- 1dB)
86%
25A x 3
200mV to 6V (+/- 5%)
260(W) x 51(H) x 294(L)mm
I am no car audio whiz, I have not tried a sundown or many brands out there that is why I am asking, how much power do you think the sae-1000 actually puts out at 1 ohm then?
that answers my questions. I have been dealing with SSA lately also, they are very good people to work with. I just can't decide on an amp.. I am willing to spend about $300 on one.
People may think I am dumb for asking this but is the rockford punch 1000d under rated or not? Which is the better amp for the money, I can get the sae-1000 and the p1000 for the same price brand new.
sundown hands down bud.
you ever get the price on a t10001?
I did not get a price on it. They are never open when I get home, my wife goes to college and works every day and is pregnant so I can't ask much more of her, she does home work afer work till about 4am, she is still doing some now..
The Rockfords 1000bds are under-rated. The one I am selling has a birth sheet of 1224. Most I have seen are in the 12xx-13xx range.
Probably at 14.4 volts to though right?? The Sundown was at 12.8 volts so at 14.4 it's probable at least a couple hundred more watts than the 1100 or whatever it was rated at.
I don't know if I believe that with 2 more volts that it will go up a couple hundred watts..
should've used a condom //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
i think it will //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Rezac
Rezac
Northfield, MN
Rezac
slater
    Oct 4, 2025
    Oct 4, 2025
