need advice for Subwoofers
  • 2
ndials925
CA
I am purchasing 2 sundown (Sa-15)'s dual 2ohm 750-watt RMS. and looking for a compatible amp.
But I am not sure I want to run 2 subs off of one amp is that even ok to do? if so which amp do I get ?(price) sky's the limit) or is it better to use two separate amps wired at 1ohm
*Noob* please help..
Get dual 4 ohm coils and wire all in parallel comes out to 1 ohm load. Then depending on your electrical any reputable 1500rms to 3000rms amp should be good (provided the later is gain set properly) . could rattle off a bunch of amps but if sky's the limit DD m2c, or incriminatory audio 20.1 get my vote.
451
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
559
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
864
ndials925
ndials925
CA
shauncox26
    May 24, 2024
