need advice for Subwoofers
ndials925
6
CA
I am purchasing 2 sundown (Sa-15)'s dual 2ohm 750-watt RMS. and looking for a compatible amp.
But I am not sure I want to run 2 subs off of one amp is that even ok to do? if so which amp do I get ?(price) sky's the limit) or is it better to use two separate amps wired at 1ohm
*Noob* please help..
Get dual 4 ohm coils and wire all in parallel comes out to 1 ohm load. Then depending on your electrical any reputable 1500rms to 3000rms amp should be good (provided the later is gain set properly) . could rattle off a bunch of amps but if sky's the limit DD m2c, or incriminatory audio 20.1 get my vote.
ndials925
ndials925
CA
shauncox26
