Need a little help!
Cali_Screw
Ok, well i need a little help. I built a box that was common chamber with two W6's and on some songs they would fight each other. Well i then put in a divider and they are still not in sequence.
However when i put in the divider i did not seal it up, could this be an issue?
All my wiring is correct as far as i know!!
any ideas?
maybe air leackage. are you sure that when you put the chamber the air space was divided correctly?
yes. even if it wasn't, the subs in theory should move in the same rythem just one would have more airspace...
well i live in fontana thats why i asked maybe i can take a look at it and see if i can find whats wrong with your set up. obviously it is if youre interested if not no sweat .
we could possibly do that. what set up are you running?
Cali_Screw
Cali_Screw
Rancho,CA
inTHEbiz
