Hi everybody, ive been out of the loop for some time now and i picked up some pieces to a used system to put in my car. Im not looking for hair trick type bass just something to feel the music. My setup is as follows
1 x 12" Dual 4ohm Kicker CVR
1 x ZX350.4 Kicker amplifier
1 x mid range JVC cd player
Power ratings for my Subwoofer:
Peak Power: 800 Watts
RMS Power: 400 Watts
Impedance: Dual4 Ohm
Sensitivity: 86.9 dB 1w/1m
Frequency Response: 25-500 Hz
Power Ratings for my Amp:
ZX Series 4-Channel Class AB Car Amplifier
RMS Power Rating:
**4 ohms: 60 watts x 4 chan.
**2 ohms: 90 watts x 4 chan.
Bridged, 4 ohms: 175 watts x 2 chan.
Max power output: 350 watts x 2 chan.
Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
Bridgeable operation
Variable high-pass filter (50-200 Hz, 12 dB/octave)
Variable low-pass filter (50-200 Hz, 12 dB/octave)
Frequency response: 20-20000 Hz
CEA-2006 compliant amplifier
So what i need to know is how to get the most power out of this amp to get the best sound out of this subwoofer. From the diagrams ive seen online it looks like i have to run it at an 8ohm load which would be way to little power. not sure if i can run it at 2ohms with my setup.
The sub is a dual 4ohm sub id ideally like to know if there is a way to wire it up at a 2ohm load bridged on the amp to get the 350W max (sub is rated at 400w rms) unless thats too much.
Also i had the idea of running each coil seperatly to the amp and bridge them would that get me close.
The amp i have is not ideal for my setup im sure but its all i have at the moment and will eventually use this kicker amp the correct way (4 channels) when i redo all my interiors and set up a new amp for the sub.
I really hope i can get this thing bumping enough to satisfy my needs for a little while, also forgot to mention its in a slot ported enclosure!
Appreciate everyones time and thanks in advance
RMS Power Rating:
