My Trunk Dimensions
  • 1
GrandAmGT
Grand Am GT in the Making
Ok, Heres my choices
1. Buy 2 Hatchback boxes Already with the Kicker L7's in them...And I would have 2 of them sealed (2 boxes, 2 subs)
2. Build a Dual Custom box INSIDE of my trunk. Harder Work, Less Money, But only 1 box instead of 2.
Ok....They will be Two 12" Kicker L7's.
Heres my Trunk Dimensions. the Max trunk dimenesions, and the ones i would wanna go with, so I have room to screw and crap.
~Left Trunk to right Side: Max=35....recomended so I have room to work=28 inches...
~Rear of the trunk to the Rear Seats: Max=30...recomended=27
~Bottom of trunk to Speaker Magnets: Max=15.5.....recomended=13
Ok, That leaves me with a good amount of room to build a Dual Sealed 12" kicker L5/L7 Box. What would the dimensions of the box be to have each sub have 2 cubic feet.....and 3 cubic feet.....-Plus, there will be a 3/4 MDF divider inbetween the subs..so remmber that too...
Wanna know my possibilities.... (Stay within the Recomended Dimensions Please)
Need to know anything else? hhe sorry for the confusion..
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
720
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
GrandAmGT
GrandAmGT
Central Wisconsin
GrandAmGT
    May 16, 2024
    May 16, 2024
