My system is cutting out.....HELP ME BEFORE I GO CRAZY
EMPIRE2000E2K
I have 2-12" JL W6v2-D4 subwoofers in a dual Ported box powered by a JL 1000/1 Amp with 2 batteries, 1 powering the car, 1 battery powering the system, a Yellow-top Optima battery and a 250AMP Tsunami Fuse. I have tried everything in my power to get this crap to work and its driving me absolutely crazy Its cutting out , someone help me before i sell this shit , I LOVE JL AUDIO so i dont wanna go lower than W6's . I turn it up on my CD Player and it just cuts out, i thought it might be the ground connection but its not cuz its grounded on the negative on the Optima Battery for the system, SOMEONE , HELP ME
So the second battery is not connected to the altenator at all?
I dont have a battery isolator , and i dont know what exactly is cutting out , my friend just put 2 12" Rockford P2's in my car with my whole setup and it didnt cut out, i had 2 JL 1000/1 Amps and it did the exact same thing with that amp
CUZ I WANT THE BEST Equipment i can get . so i said F' It and got it
//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif A second battery will not help you in most cases. If you have not upgraded your altenator then the altenator might not be able to charge a second battery sufficiently.
I say remove the battery, do the Big Three, and see what happens. If you have voltage problems still, then get an HO alt.
EMPIRE2000E2K
EMPIRE2000E2K
Wooster Ohio
Psyence
