My Pre Out Voltage Predicament. What’s your $0.02?
I think there is notable quality difference. A decent deck with a good dc/dc converter and 24bit dac will outperform 99% of the ones with crappier dacs and lower preouts. they usually go hand in hand. amping a smaller signal results in more distortion. a line driver will help but i would just suggest a better deck or an audio control eq. dont compromise sq for bells and whistles
Also bryan can attest that having the higher volts does help just in going from 4 to 6.5
Thanks, you hit the nail on the head. This was the kind of advice I was looking for. I agree 100% about the bells and whistles, but I just cant spend any coin on a new HU right now. The audio control EQ's seems to be a better alternative but I would have to come across a good used one at a good price.
BTW, you right the dc/dc converter in this unit s**ks. //content.invisioncic.com/y282845/emoticons/wave.gif.002382ce7d7c19757ab945cc69819de1.gif
Sounds more like you wanted someone to agree with you, as oppose to inform you.
My first deck was an Alpine CDA 9847 with 4Vpreouts. My current deck, a Pioneer DEH-P6600, sounds way better.....& it has 2V preouts.
My .02 is that the only pro's for higher preouts is that you can set the gain lower. The pros of that are of course that the amp will run cooler and less distortion. Moreso the amp will run cooler.
True, however, none of that really matters if you have a nice amp.
My god, so much misinformation in here it's ******* ridiculous. Helotaxi already stated it, the SQ of your system depends on the quality of your equipment NOT the pre-out voltage. If your amplifier is of any quality at all there will be no audible difference between a 2v, 4v, 6v, or even 8v preout, PERIOD. Stop buying cheap equipment then worrying about SQ, that's like buying a Ford Taurus and worrying about what your quarter mile time is.
As a side note...helotaxi where the heck have you been? I haven't seen you around for a long time...
My god, so much misinformation in here it's ******* ridiculous. Helotaxi already stated it, the SQ of your system depends on the quality of your equipment NOT the pre-out voltage. If your amplifier is of any quality at all there will be no audible difference between a 2v, 4v, 6v, or even 8v preout, PERIOD. Stop buying cheap equipment then worrying about SQ, that's like buying a Ford Mustang and worrying about what your quarter mile time is.As a side note...helotaxi where the heck have you been? I haven't seen you around for a long time...
fixed //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Introduced in 1989 with an MSRP tag of $1,200. Named the best head unit of all-time, in a car audio magazine I read earlier this year. However, it had 4v pre-outs. lol
Its 500mV
Specifications:General:
Output voltage (Preamp) ~ 500mV
Bass Adjustment ~ +/- 18 dB @ 30 Hz
Treble Adjustment ~ +/- 15 dB @ 15 kHz
Dimensions ~W 7" x H 2" x D 6-1/8"
Compact Disc Player:
Samplying Freq ~ 352.8 kHz (8x Oversampling)
# of D/A Converters ~ 2
# of Quantization Bits ~16-Bit Linear System
Freq. Response ~ 5 Hz - 20 kHz
Wow & Flutter ~ below measurable limits
THD ~ 0.002% @ 1 kHz
Dynamic Range ~ 100 dB
SNR ~ 110 dBA
Channel Separation ~ 95 dB @ 1 kHz
AM Tuner:
Sensitivity ~ 10 uV
FM Tuner:
Mono usable sensitivity ~ 16.3 dBf (1.8 uV/75 ohm)
50 dB Quiet Sensitivity ~ 20.7 dBf (3.0 uV / 75 ohm)
alternater channel selectivity ~ 80 dB
SNR ~ 60 dB
Stereo Separation ~ 35 dB
Capture Radio ~ 2.0 dB
AM suppression ~ 45 dB
interesting. The article I read said 4V, I guess Alpine would be a better source.
A little off topic but here is a screenshot out of the 7909 manual:
To provide a clearer picture my amp is a Alpine MRV-F345
  • 75 watts RMS x 4 at 4 ohms (85 watts RMS x 4 at 2 ohms)
  • 300 watts RMS x 1 (channels 3/4) + 75 watts RMS x 1 (channels 1/2) in bridged mode
  • Amp Link allows single cable connection for signal and control with compatible Alpine receivers
  • 2-, 3-, or 4-channel output
  • Tri-way capable (Tri-Way Crossover required)
  • requires 8-gauge power and ground leads
  • Bass Engine® features:
  • Variable 30-400 Hz high-pass/low-pass digital filters, 12 or 24 dB/octave
  • Rear channels have a subsonic filter at 15 Hz
  • MOSFET power supply
  • STAR Topology (minimizes internal noise and prevents ground interference)
  • Speaker- and preamp-level inputs
yeah that, just as long as your amp can take the voltage. I have an orion amp that maxes input voltage at 4V.
I just bought an Alpine R-A75M for my sub woofers, and later plan on adding the Alpine R-A60F. My plan was to wire these with 3 sets of RCAs; one...
Sounds like you need new coils. My Explorer with three 15's, appropriate birch box, fully sound-deadened interior, and a boat behind it does not...
Ive competed in car audio since 1991 and unless something is faulty in the amp and its staying on all the time it wont drain your batteries ..the...
-DOZER-
-DOZER-
Toluca Lake, CA
helotaxi
