winkychevelle 10+ year member
screw u moving air doesnt mean its loudit was loud enough to do hair tricks with your moms 70's bush
noob just said the best thing in this threadported boxs are wayyy better im runing a single 18 and a memphis 4k with a 8 inch flared aero port and doing 149.5s if you have no room for a port loose a sub and run more rms to each and do a port.....way louder n sound way better
or you couldve just mounted the amps differently and manufacturer box specs arent normally accurate for givving you the best results, they give you those specs so that you can toss the subs in there and not have to worry about blowing them, where as you can build different boxes that work well for those subs and your vehicle and still not worry about blowing the subs. ever wonder why kickers box range is so vast? its because one box doesnt work the same in every vehicle.I was just going off of what the subs are rated at, 750 rms in a small sealed enclosure, or 600 in a large sealed/ported enclosure, my amps birth sheet at 1321 and 1340 rms, so that's like 660/670 per sub in a medium size sealed box, I figure they match up pretty good. My main concern was to have a box small enough to fit under the cargo cover so it can't be seen. Yes I have an alarm, and no I don't bump around my house, I still don't want people walking by and seeing what's in it in a parking lot neighborhood, etc. Couldn't fit a large ported/spl box in those parameters. My options were small, minimum spec ported box(sq ported box) taking up max available space and mount amps directly to back of box, or sealed enclosure/amp rack. I opted for the later
How about 157 on the glass with 2 12inch mojos?? Heres my rideI think the whole world wide web would shut down if someone posted a YouTube vid of some w7's or mojos hitting 150
no you set a small bomb off in the yogoDid I blow up the internet??
