My New subs
Kursed
NY
i was so happy i when i got them i had to take some pictures.
My box i will be building(if anyone could give suggestions for better or see if there is any mistake to this diagram would be a lot of help)
i ordered two Hifonics BX1800D and a 170amp alternator and a lot of 0gauge wire and 12gauge speaker wire and a new yellow top.
ohh ok. in the diagram how come " H " isnt used? if its not used should i just edit that piece out side i dont put it in there bymistake when building.
it's a generic design, the H is there in case the port has to be longer than the box is deep, in this case, it doesn't' so you only need the first part of the port
you can just take it out b/c you will not be using it
yes it is part of the port, but i'm going by the diagram at the top where it says H isn't used, i assumed RE just made a generic diagram and this one didnt' need H so they just said it instead of removing it
it did seem odd that it only need to be 13in deep and be tuned as low as it is, but maybe that's just me
Kursed
Kursed
NY
Kursed
michigan born
    May 14, 2026
michigan born
    May 14, 2026
