does sharing airspace hurt a subwoofer
FSUNole17
hey i wanted to use a 12W7 and add 2 jl 8W3V2's for just some icing on the cake for extra punch, is it bad if they share the same airspace in a sealed enclosure, would it hurt the performance any of either of the 3 woofers or woudl i be beter putting them in 3 seperate compartments, thanks!
clay
It would be better if you didn't even bother adding the 8w3's //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Typically, you don't want to mix and match sub sizes and styles (i.e. a W7 with a W3v2). They have different frequency responses and such that more than likely won't blend well together. Also, the W7 will likely drown out the 8's....rendering them useless and a waste of money and install time.
FSUNole17
FSUNole17
franklin, tn
squeak9798
michigan born
    May 14, 2026
michigan born
    May 14, 2026
