My Friend cut the end of my battery cord that goes to my amp
I didn't know they sold em.. So just ask for a wire terminal? And how exactly do u Smush or clamp it on?
are you talking about the main cable for the car (alt,starter,lights,etc) or the wire directly going to the amp?
any links to free chat gpt 4 access? I haven't been able to find anything that isn't behind a paywall.. I want to take this cyber bish for a ride.
29
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
77
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
981
If I was in your situation, I would experiment with the wring for a day or two. If that didn't work, I would purchase an external amplifier. Run...
Rik Is Ripe
Rik Is Ripe
Ga
Bettr n' Revrse
    May 12, 2024
Brendon Jenness
    May 11, 2024
