My false floor is almost complete...
Building a false floor for my FJ Cruiser and it is ~90% complete. I still need to cutout the holes for the lexan, cut and wrap the lexan in frosted glass tint, cut the designs, and carpet it. Should be an hour or two tomorrow. Anyway on to the pics.
Bottom:
Countersunk screws:
Side height 2.5"
Sides attached:
Removable Front finished for accessing and easily adjusting amp settings:
Removable front set in place:
Front and back pieces completed:
Battery in place (and one of my dogs):
Battery
One more:
Tell me what you think and give me any advise to make it better!
Original design was to have it on the left side but then the lexan would not have been symmetrical and that would have driven me nuts. I left room to run my wires and I'm shopping for a battery box now. If not I'll make my own.
Anyway more pics. Today I got my holes cut for my Lexan, got the lexan cut, get the design done and the lexan frosted. I got one side wired for leds, but didn't have flux to wire the other side. I also need to get another piece of lexan since my saw decided to kick it out and it left a large scratch on one of the pieces. I went ahead and worked with it since it will be a while before i get another piece.
Holes cut
Lexan in place
Almost finished, just needs carpet
Lexan and LED's
Another shot of the Lexan lit up
More pics tomorrow since I'm done working today and I'm hungry.
Jesse you need to step your game up bro!
I was going to do the Omega symbol but decided that since their was a large one on the box that I would do the Fj symbol on both sides. I messed up the one piece of Lexan so I might change it when I redo it.
I used this Lexan....
http://www.amazon.com/Polycarbonate-Sheet-Clear-Thick-Length/dp/B000FPC3Z0/ref=sr_1_1?ie=UTF8&qid=1322441980&sr=8-1
and these LED's...
http://www.amazon.com/gp/product/B002Q93CGM/ref=oh_o01_s00_i00_details
I used my table saw to cut it to 8" x 8" squares then taped it off and drew/traced the design. Then I used a utility knife and straight edge to cut out the design, leaving the design and removing all the excess tape. I used my Dremel multi-max with the sanding attachment to frost it. It went very quickly and I used a straight edge to get up to the tape (even if you hit the tape its okay). Then remove the tape and wipe it down with alcohol. Very easy to do.
Also be careful cutting the lexan and take it slow. I pushed too hard and it kicked out. One side flew across my shed and the other hit me in the stomach. Good thing I was wearing gloves and multiple layers of clothing because it flew out with some serious force. If you take it very slow it won't do it. When I was recutting I let it go through at its own pace and didn't get any binding or anything.
OmegaBunny
Moderator
OmegaBunny
Keyser, West Virginia, United States
OmegaBunny
