My false floor is almost complete...
I was going to do the Omega symbol but decided that since their was a large one on the box that I would do the Fj symbol on both sides. I messed up the one piece of Lexan so I might change it when I redo it.
I used this Lexan....
Amazon.com: Polycarbonate Sheet, ASTM D 3935, Clear, 1/4" Thick, 12" Width, 24" Length: Industrial & Scientific
and these LED's...
Amazon.com: Flexible Lighting Strip 300 SMD LED Ribbon 5 Meter or 16.4 Ft 12 volt BLUE, 2026BU: Home Improvement
I used my table saw to cut it to 8" x 8" squares then taped it off and drew/traced the design. Then I used a utility knife and straight edge to cut out the design, leaving the design and removing all the excess tape. I used my Dremel multi-max with the sanding attachment to frost it. It went very quickly and I used a straight edge to get up to the tape (even if you hit the tape its okay). Then remove the tape and wipe it down with alcohol. Very easy to do.
thanks for that info.
OmegaBunny
Moderator
OmegaBunny
Keyser, West Virginia, United States
OmegaBunny
michigan born
    May 14, 2026
michigan born
    May 14, 2026
