Mustang Box
Hawaiian
CA
I am away from my car right now (on break back home) and I am trying to estimate the amount of space (lxwxh) I have in my trunk for a box. Anyone with a mustang (the newer ones mine is a 2000) know the specs for my trunk?
Thanks
Go measure your trunk for your car...Then give me the measuremnts I can tell ya what u have to work with..Cause I dont know about the new cars..I have a 1995 mustang..And the new mustangs have an upgraded trunk from the former model! Lengthxheightxwidth...Then i can give u the Cubes u have to work with!
Blake
Originally posted by SoundsUnlimited Go measure your trunk for your car...Then give me the measuremnts I can tell ya what u have to work with..Cause I dont know about the new cars..I have a 1995 mustang..And the new mustangs have an upgraded trunk from the former model! Lengthxheightxwidth...Then i can give u the Cubes u have to work with!
Blake
The 1994-2002 cars have identical trunk space. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I drive a 2000 Mustang and the trunk space isn't that large, but with molded fiberglass boxes - such as I have resorted to building at the present time - you can achieve quite a bit of air space and still have some room left over.
If you are going with a more standard wood/MDF enclosure, you will probably find (as I did) that boxes must compensate for the small trunk opening. I originally built a box for three 10's and had to slant the face to reduce overall height and slide the box in through the rear seat opening, then screw in the top-firing sub afterwards; a real pain in the butt and I couldn't even turn the box around to fire the subs backwards, so it was unacceptable for anything beyond a "casual" install.
Although I can't tell you the precise dimensions, I *highly* recommend molded enclosures.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Might not even be an issue if you don't have any really big panels on it. Otherwise dowels or threaded rod across your wide panels would be the...
18
I ordered the car with the upgraded B&O audio system....turn's out Ford bought the name but they didn't buy the quality. The system ****** to me...
Contact ANS he has a used Focal 8 Channel DSP that went for 1,300 bucks and is selling used I think shipped for 450. And from what I have seen and...
13
409
Hawaiian
Hawaiian
CA
Diabolic
    May 16, 2024
    May 16, 2024
