MTX 8000's what vol. box?
  • Thread starter Unregistered
  • Start date
  • Replies 2
  • Views 2K
  • 2
U
Unregistered
Guest
I recently bought 2 12" MTX 8000's and a 1200W Kenwood Excelon Mono Sub amp. I want to put both the subs in a single sealed box, although i want the bass to sound nice and loud with out messing up how tight the bass is. What should I make the volume of the box be?
well the book says to have from 1 to 2 cubic feet per sub. i think that the best sound would be around 1.25 per sub. so if yuor goin to have a box with no divider make it about 2.5 cubic feet but other wise 1.25 or so should be good for those subs
I own a pair of thuner 8000 12's and I have them running in a 1.25cft(each) enclosure, I think they sound excellent, but if you want them to sound really "tight" I would recommend you use a 1.1cft(each) enclosure.
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
877
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
If I didn't have my two 4500s already I would probably try the Creampie 7500/ Slapz 8k. :poop:
Guest
stones
chillin
    Jun 14, 2024
