mounting to back of box
well the rubber gromits would be for vibrations, if they would make that much vibration. box is 4.5cu at 35hz. two alpine type r's. built with .75inch thick mdf if that helps
i wouldnt worry about it if its secured good enough.. try it out.. doesnt seem right to you.. add em, but i never had a problem without em
Vibration can damage some amps over a period of time.
yeah well no matter how hard you bolt it down.. its gonna vibrate along with the car.. plus pot holes.. speed bumps ect...
just get it down tight as possible...
You should have used 3/4 inch MDF, .75 inch will not hold two type r's
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the...
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
335
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
It is a wives tale if the only evidence could be coincidental. I agree that vibration is bad for everything except women, but that doesn't mean...
32
6K
taintedplay
taintedplay
dallas
Redlineaudio
    May 20, 2024
    May 20, 2024
