XTRProBoy
I'm trying to mount a sub in a fiberglass box (designed for the car) however the sub is slightly too deep for the box. The mouting ring on the box is recessed as well (a sub less deep woudl sit flush) so I've had to use two rings, one to sit in the recess and get to the level of the rest of the box and then another one on top of that because I still need just a little bit more depth to get the driver in there.
So what I did was I drilled the 8 holes through the two rings and then glued them together with Liquid Nails. To set the ring I put screws through the 8 holes to hold them together. My initial intention was to do that, remove the screws, and then drive the 8 screws for the sub straight through the rings, and then into the ring that the box has to hold the sub. However I then thought with my screws all in there I might as well leave those to hold the two spacer rings together permanently and then make new holes by offsetting the ring and driving through the screws for sub like that.
Then I got to thinking again, lol. What's the better way to do this?
Should I
a. Leave the ring as is with the screws, then drive 8 more screws through there and through the ring in the box which will hold the sub and the spacer rings to the box? (This is what I mentioned last above.)
OR
b. Should I instead mount the rings to the box with 8 screws (going through the two rings plus the box) and then mount the sub to the top spacer rings (without the sub-securing screws going through the box)?
I thought about doing both but then I'm not sure I want to make 16 holes through the ring built into the box so it should be one way or the other. What does everyone think? Rings secured together and then sub driven through all the rings; or rings secured to the box and then sub secured to the rings?
Is there even a difference?
Should I
OR
