mount depth
  • 2
KAMAK
Corvette=Good
376
michigan
I have a couple problem. I want the cdt-cl61 of of the zeb. In my 1997 chevy montecarlo it say the front has 5 1/4 size speakers. The cdt's are 6.5. Can i make them fit? Also can anyone tell me my mounting depth and also tell me if the cdt's will fit depth wise either. I know i am asking for alot but i would really appreciate it. Thanks:)
The mounting depth is 2 and 7/8 inches....I suggest you make an MDF mounting ring and have the base go into the stock 5.25 opening so you can avoid doing any cutting of the door....
Originally posted by Gauntlet The mounting depth is 2 and 7/8 inches....I suggest you make an MDF mounting ring and have the base go into the stock 5.25 opening so you can avoid doing any cutting of the door....
OK so i can get those speakers. Thanks for the answer i will order them. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif (how about powering them with a usx-2080 will that be enough power?)
Originally posted by Gauntlet I would check what's going on in your door and try to plan the install out before you order the speakers just to make sure....and the 2080 is a great choice.
Ill make it work:D
  • Locked
The models with squared off buttons and blue lights, open to various models.
  • Locked
Here's a longshot. I'm trying to find a second set of these tweeter mounts. They are flush mounted, and fit my tweeters better than the mounts...
  • Locked
COMPLETED Shallow Mount 10
I hear ya man... I get it
29
6K
It's fine to mount to the box. A lot of show car SPL setups have amps or other electronics mounted directly to the wood frame of the box or on an...
21
They make sleeves that go over the battery terminal to increase its size.
KAMAK
Corvette=Good
KAMAK
michigan
KAMAK
