**** Mother ****ing Install!
yea set the dmm to resistance/ohms. put it to the terminals of the mids and if reads the impedance to roughly what the speaker is supposed to be then the speaker is good. if it reads zero, it's blown.
DMM set to ohm (200), it reads 3.8 (4 ohm mid) (only did the passanger side because that door panel is off already, figured at least that one should be working with the right reading). What next?
do u have a crossover for ur mids and highs? if so, and ur tweets play, somethin might be ****ed with ur crossovers. idk much about components and whatnot but its just a thought lol
Amp has output, check speaker wire
No output, pull RCAs out fo amp and mesure voltage of RCAs
Voltage from RCAs...Amp may be bad
No voltage...pull deck and make sure they are not loose
RCAs unhooked...you found the problem
RCAs hooked up...either a setting in your deck is off, or the output of the deck is bad. Pull RCA from another source and test.
What do I set the DMM to to check the RCA's. I have a feeling that it is the DQX (x-over) that is having the problem.
Could be I havent done it in forever...
I don't know what the **** is going on. Are you going to be at your house tom?
DMM>me I couldn't seem to get a reading on anything, even the RCA's that are obviously working. This is flat out pssing me off.
mikeyboc
mikeyboc
Sugar Land, TX
mikeyboc
BP1Fanatic
BP1Fanatic
