More output
mythyone
Sadly im wanting more output than my SE's. They do sound amazing but im looking for something with a little more focus on SPL. I have the 1 AQ1200 right now for power so i want something in that range of power needs. I dont really have a budget as im gonna be saving up for something new, just trying to getting some ideas.
The AQ1200D was designed around the SDC2.5 series and is the perfect match for a pair.
Thanks for the sugestions, im gonna look more at the AQ subs but i wanna get metered with the SE's first. My main goal is to do 140db+ daily driver so i may be hitting that right now and not know it :p If not i may get a second AQ1200 and another pair of Se's and see what that does in a wall in my truck //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
true but if u wanna see some fun dj u should have seen what matt did with your 4 sd2.5 15s
//content.invisioncic.com/y282845/emoticons/popcorn.gif.32dd9e22fd77e77bc3c907062768fcd2.gif
//content.invisioncic.com/y282845/emoticons/awesome.gif.4430a219d9aaaa6cadc75e9290979dfb.gif
//content.invisioncic.com/y282845/emoticons/blackeye.gif.66a1670f5aaf7f406e783a63e3387dc5.gif
EASY
MAKE UR BOX 5CUBES TUNED TO 40HZ WITH 100 SQUARE INCH PORT
80
Yeah, you have some nice stuff mang. That AQ amp should push those SE's real nice.
Nice ported box should do the trick, also make sure your electrical is up to par. Might be having voltage drops and might be a lot of the reason.
I am having some voltage drops with some of the longer bass notes. Im gonna be doing the Big 3 and see if that helps.
mythyone
mythyone
Greenbay, WI
Papermaker85
michigan born
    May 14, 2026
michigan born
    May 14, 2026
