Have you ever seen a truck with a blow though put more subs inside the cab?
Is it? Could there be other reasons?
Why cut the truck if you have room for the subs already?
It can be just for space. People can do something like a series 6th and have the ported rear section in the bed or something and have the cabin portion be the front chamber. That would be extreme and hard to design, but doable. I've done the same things with walls where if someone's wall isn't big enough we start going backwards into the trunk and cutting away the trunk rear deck to get more space, but you start getting difficult geometry to calculate.
Because there isn't enough room for the subs you want to run inside of the cab. But there is room inside of the cab to run something different or to try and fill in 80hz and above. This is just brain storming for SPL types of systems.
With anything, if it's done correctly, it can work, whoever designs and builds it just has to know what they're doing. The physics and layout has to work.
That's my biggest concern. I'm just exploring ideas right now. Possibly dumb ideas. haha
All that essentially boils down to space for the subs 😂
Yes, I'm just explaining in detail. I've done walls where we're approaching north of 40 cubic feet net, not outside but total usable airspace. I'd have to go check but doing walls with 20-40 cubes net airspace isn't uncommon in full vehicle walls, especially with bandpasses, just really depends on vehicle size, obviously. So, people doing hardcore builds have to resort to these tactics, because we're insane or something idk 🤷‍♂️
What about a walk through? Camper shell? Remove rear window port through rear window?
This is my IG, I am not designing for anyone right now, but maybe some ideas a for you:
TheRamSonus
CarAudio.com Recruit
TheRamSonus
WA
shredder1
