MM4000.1 1 ohm daily
Will a MM4000.1 run 1 ohm daily?
  • Yes
    Votes: 8 44.4%
  • No
    Votes: 10 55.6%
  • Total voters
    18
People always say you can do anything with good voltage. It helps, but it doesnt make a 2 ohm stable amp run at 1 ohm. Just like it doesnt make a 4 ohm stable amp run at 2 ohms.
If you had good voltage would you run a 4 channel with each channel @ 1 ohm when it is only stable at 2?
Exactly. The 3000.1 is a 1 ohm stable amp.
The 4000.1 isnt.
The amp is 1 Ohm STEREO which is the same as 2 ohm mono.
The differance between the 3000 and the 4000 is the internals.The 3000 is one amp which can be strapped.The 4000 is 2 mono amps already strapped internally.That is why it is only rated for 2 ohm mono and 1 ohm stereo.
terra
terra
Yes
tooloud4tv
