Mini Suv Enclosure Position/Orientaion
I have no idea what good sounds like to you, you know? Let us know how it goes, it'll be interesting to see.
Ok so I got it pushed back and it doesn't seem as loud.
---------- Post added at 07:37 PM ---------- Previous post was at 07:37 PM ----------
played lows stronger and more bandwidth up top as well, peaked around the same. Just overall output was much higher hence better bandwidth overall.
Ok I got it pushed back and it doesn't seem as loud IMO...
thats hella wierd then. Guess each car is different.
thats what im thinking... I could have something to do with the way the Kia is Shaped or the way shape the roof is in the back corner of hatch that meets the roof.
When i did it when to the normal volume i would "demo" at(though i really dont demo) and i could tell there was a difference in performance. Also it made my break light in the window sound like *** lol. So i just moved it back for the time being. I plan to build another box sub up port back or go with 1 18 and keep firing sub and port up. If i do the 18 i plan to downgrade power though. Probably wire up to 1 ohm and find a "efficient" 18 like the FU 750-18 or Sundown Sa18 that way i dont need as much power but keep my same amp
Hit me up //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Curious, im just playing around with a enclosure calculator because im bored at work lol... I was trying to come up with alittle something for my DP15. I looked at what IA recommends but it seems really generic. It just says 3-5 cubes net - 80 sq inches of port - 32-37hz tuning.
I know the enclosure size will depend on the power also, but what would be the ideal Enclosure size Net and port that i should be aiming for. I would probably tune 35-36 range like i usually do
4-4.5 cubes, probably 16 in^2 per cube
I am assuming you saying 16" per cube that your refering to a slot port. In this kia i dont have the depth to do a Aeroport and tune it were it want it, but a slot port will work and can tune it were i want it
bgowdy
Heroes are remembered, but legends never die
bgowdy
Campbellsville, Ky
Buck
