MB Quart DSC-1500.1D for a pair of Sundown SA-8?
chasinSKURT
live laugh lolz
I am confident that this amp will put out the rated 1500rms, but im not sure if this amp is a good match for a pair of SA-8 D4 subs.
Im not as concerned with SPL as i am with SQ.
specs for SA-8 D4 Subs:
400 Watts Continuous Power Handling
RE: 3.28 ohms (series)
FS: 41.6 Hz
Qes: 0.513
Qms: 6.606
Qts: 0.476
Le: 2.778 mH
Vas: 3.285 L
BL: 17.138 N/A
Cms: 83.341 um/N
Mms: 175.654 g
Sens: 78.476 dB @ 1w/1m
SQ on a subwoofer is relative, provided the amplifier can make the power you need over the frequencies your music feeds to it. Some class d amplifiers struggle below 50 Hz to make any form of decent power, and sadly, they are generally Maxxsonics products. Then again, with 1,500 watts on tap at 1 ohm, it should be able to meet your needs for 800 watts RMS between 20 and 80 Hz. If not, it will be pretty dang close!
i heard Hifonics had problems putting out the rated rms.
Is it true?
i would say yes, but it isnt grossly overrated. I think its close enough that it can still be considered a quality budget item.
For comparison sake, i just went from a Fosgate 800a2, which is fairly powerful (birthsheet stated 1100rms) and my hifonics 1508d seems to be more powerful, although the Fosgate sounded better on low bass notes. I dont know an exact number, but im sure Hifonics does about 80% of rated power
i would say yes, but it isnt grossly overrated. I think its close enough that it can still be considered a quality budget item.For comparison sake, i just went from a Fosgate 800a2, which is fairly powerful (birthsheet stated 1100rms) and my hifonics 1508d seems to be more powerful, although the Fosgate sounded better on low bass notes. I dont know an exact number, but im sure Hifonics does about 80% of rated power
Yeah, most complaints about them being overrated were by about 100-200watts, so right in that 80% range like you said. Realistically, it's not that much, inaudible even. But you know how it goes - once someone finds a something wrong with something, all hell breaks loose on CA //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
The Timpano amps are also small. I bought a small 1400 watt Timpano mono amp. I was impressed by the power I could get from it, but they have a...
15
Hello, I have bought a set of speakers but I want some recommendation of an amplifier that can work very well in them. 1 pair of RS1-216 1 pair of...
According to Crutchfield, those JLs won;t fit in your dash, can't see why, just what it says on their site. it says those JL's won;t fit in the...
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
522
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
797
chasinSKURT
live laugh lolz
chasinSKURT
Austin, Texas
DarkScorpion
Decebal
    Jun 10, 2024
