MazzaSEC Build log! Sundown, Fi, Deka, PG RSDS
so with the 3000d @ .5 ohms on 3 batteries you were dropping to 12.2 volts with the gain set at what?
i understand it was all the way down but have you measured what your putting out with the gain all the way down?
and what size is your stock alt?
just trying to get a little understanding for my next setup
I hope you don't mind me asking but why did you swap out the 2 1500's for just one 3000?
Would you even noticed a difference to the ear?
because its badass
and i would personally rather run one amp then 2. when you deal with 2 then you deal with exact setting and so on, more wiring, more space. and i would rather run one amp at .5 then 2 (this is in his setup)
With the 2 18" there would have been no way I could fit 2 1500ds with the space I had left. I cant even find a good place to mount the 3000d.
Hey skip01, the sub and amps are going into an extended cad s10. It's in ISACA advance no wall 1. We were running a memphis mojo megamax in it with 4 moded rockford T2000.1BD's and we did a 156.7 at SBN, but we blow the sub and caught all 4 amps on fire twice since then. We are hoping to hit a 160 or realy close to it with the new setup.
So after playing around with it some more today it seems to be doing just what I want it to do! Definetly louder then the BL's and at a lower frequency to. My BL's in there boxed peaked at around 47-50hz. The Alpha 18"s peak around 39-43hz which is exactly where I wanted it to peak at! Only issue I see as of right now is the voltage once that is fixed up this thing will do bad things! Once again big thanks to Mike for helping out with the box! So far so good!
mazzasec
Banned
mazzasec
ATL
Rawr-DQ
