Matching sub to box
DinSeadly
So i recently blew one of my subs and I am looking into replacing it or possibly replacing both subs if thats what needs to happen. Currently I have one of these(managed to seize the second one :p):
http://www.clarion.com/ca/en/MungoBlobs/533/903/SRW1285(Manual),1.pdf
The box i have is a Bassworx box, not sure if they are any good I bought the set up used. The box i have is a ported one, it is (according to the website) 3 cu.ft. volume and tuned to 42 hz as I found here: Bassworx - Industrial Revolution (Mine is the dual 12").
I am hoping someone can help point me in the correct direction of what sub to replace my one seized up one with or if i should look into 2 new subs. The amp i am running is a Kaption Mono 700 RMS 1ohm. Any help would be appreciated! Thank you
p.s it would be nice if the new subs i got (if needed be) are much harder to blow or impossible to blow with this amp.
I dont really want to buy\make a new box, i dont really have the money right now and was more looking for a quick fix of just replacing the one missing sub or replacing both subs. I honestly am not sure HOW the first one blew, it just did. It was causing my amp to go into protection mode when I turned the volume up past 20. I tore the seized sub apart and found the voice coil was completely black :p.
there is also a 2 farahd cap hooked up however, thought that helped with the drop.
not really, it does serve as a fancy looking distribution block tho! Definately get 2 new subs, dont mismatch... altho back in the day i have to say i mismatched a few times that didnt sound too bad...
DinSeadly
DinSeadly
Ontario, Canada
destined2race
